To modify assignments, go to the Subtype subtab of the Security tab and do the following:
Select Role from the View Subtype By drop-down list.
Expand the node (+) of the object type. All the subtypes appear.
Expand the node (+) of the object subtype. All the roles currently assigned to any operation on the subtype appear.
Click the icon in the Manage column of the role whose assignments you want to modify. The Add Operation for Role screen appears.
Double-click on an operation in the Available Operations column to move it into the Selected Roles column and assign it to the role.
You can also select multiple operations by using Shift+Click or Control+Click and use the arrows to move one, a few, or all at once to the column in the shuttle.
You can change the order of the operations using the Up and Down arrows on the right. The display order has no functional effect.
Click Apply. The system adds the operations to the role for the subtype and the Manage Subtype screen appears.
