Notes on Particular Object Types
Some object types require some explanation:
- Execution Setups. To delete or modify an Execution Setup, a user must also have Modify privileges on the object instance that owns the Execution Setup. Therefore, any role you assign to Remove or Modify Execution Setups, you should also assign to Modify the type executable object whose Execution Setup it can remove or modify.
- Adapter Domains and Adapter Areas. These include all the same operations that Domains and Application Areas have. However, only view operations on some objects are required; see Creating Roles with the Required Operations for Adapters.
