Objects Excluded
The following objects are not exported:
- All validation supporting information including all supporting outputs and supporting documents.
- The classification hierarchy assigned to any object. On import, the default of the target Oracle Life Sciences Data Hub instance's classification is used for that object type.
- The subtype of any object. On import the default subtype of the target Oracle LSH instance is used for each object type.
- Checkin and checkout comments.
- Execution and Work Area installation data (jobs, outputs, data).
- All other object types: Adapter Domains, Adapter Areas, Workflows, Report Sets, Data Marts.
- Other Oracle LSH metadata: Users, User Groups, Roles, Subtypes, Adapter Security, Database Accounts, Remote Locations and Connections, Service Locations, Hierarchies, Terms, and Subtypes.
Parent topic: Objects Included and Excluded
