Objects Included
The following object types can be included:
- All organizational (container) objects: Domains, Application Areas, and Work Areas. If you export a whole Domain, all nested Domains and other organizational objects contained in it are included. If you export objects at a lower level of the object hierarchy, the utility automatically includes all parent objects up to the top-level Domain.
- All object definitions of the following types contained in the included Domains and Application Areas: Tables, Load Sets, Programs, Variables, Parameters, Parameter Sets, and Business Areas.
- All the object instances of the same types contained in the Work Areas: Table instances, Load Set instances, Program instances, Parameter Set instances, and Business Area instances.
- Underlying object definitions for the included object instances that are contained within the Domain specified for export. That is, if you specify an object instance for export but not its underlying object definition, the system automatically includes the definition if it is included in the same Domain.
If the underlying object definition of an included object instance is located in a Domain outside the one you specify, the object instance cannot be imported correctly and the export log file contains a warning. - Secondary objects contained in primary object definitions:
- Table definition: Columns and Table Constraints
- Load Set definition: Table Descriptors, Planned Outputs, and Parameter Set instances
- Program definition: Table Descriptors, Parameter Set instances, Source Code definitions and instances, and Planned Outputs
A single line of source code text that has more than 32765 characters does not get exported correctly. - Business Area definition: Table Descriptors, Joins, and Hierarchies
- Secondary objects contained in the following primary object instance types:
- Table instance: Table Constraints
- Load Set instance: Mappings
- Program instance: Mappings
- Business Area instance: Mappings
In addition to the above objects, the following Oracle LSH object components are also exported:
- Version labels
- All runnable active Execution Setups for all instances being exported, including backchain Execution Setups
All versions of versioned objects are included, except for Work Areas, for which only the most recent version is included. Domains and Application Areas are not versioned.
Parent topic: Objects Included and Excluded
