Roles and Privileges Required for Importing Domains
When you execute the script you must supply an Oracle Life Sciences Data Hub user account.
The user account must have the following privileges:
- LSH Checkin Admin application role. This role is essential for importing or upgrading a Domain.
- LSH Bootstrap Admin application role. This role is required only for creating new Domains, not for Domain upgrades. This role allows an application user to create the Domain and objects under it.
- Sufficient privileges to be able to install Oracle LSH Work Areas.
This user does not require any other privileges to run the import because object security is temporarily granted to this user as part of the import process.
See Setting Up the Security System for more information.
Parent topic: Importing Objects
