Importing Objects
The import script checks to determine whether a Domain with the same name as the Domain being imported already exists. If it does, it checks whether the existing Domain was also created using the import script.
If the existing Domain is not an imported Domain, the import script creates a new Domain. If the existing Domain is an imported Domain, it upgrades objects that have new versions, allowing you to deploy new versions of an Oracle LSH application on the target Oracle LSH instance.
- Upgrading an Existing Domain
This section describes how to upgrade the existing domain with the import script. - Roles and Privileges Required for Importing Domains
When you execute the script you must supply an Oracle Life Sciences Data Hub user account. - Creating the Directory and Running the Import Script
To import an Oracle Life Sciences Data Hub Domain, run the following commands from the database server where your target Oracle LSH instance is installed. - Import Log File Content
The import log file contains any errors that the system encounters while creating objects in the target Oracle Life Sciences Data Hub instance and many other details on objects, locations and connections (for example, results of running install scripts). - Applying Security to an Imported Domain
You must assign at least one user group to a new imported Domain (not required for an upgraded imported Domain) to be able to view and use the other objects imported in it.
Parent topic: Exporting and Importing Objects
