Applying Security to an Imported Domain
You must assign at least one user group to a new imported Domain (not required for an upgraded imported Domain) to be able to view and use the other objects imported in it.
You must have the LSH Bootstrap Admin Role for this operation.
From the Domain's properties screen, do the following:
  1. From the Actions drop-down list, select Apply Security and click Go. The system opens the Manage Security screen.
  2. Click Assign Group. The system opens the Search User Group screen.
  3. If you know the name of the user group you want to assign to the Domain, enter it in the Group Name field. You can also enter part of a name and the system will return all groups that include the string you enter in their name. If you leave the field blank, the system returns all user groups.
  4. Click Go. The system displays all user groups that satisfy your query.
  5. Select any number of user groups: click their Select check box and click Apply.
  6. Click Return to return to the Properties screen for the Domain.
