Create a Column from an Existing Variable
You can create individual Columns as instances of existing Columns, as you can for other objects.
In the case of Columns, a Column definition is really a Variable.
For instructions, see Creating an Instance of an Existing Definition.
Parent topic: Defining Table Columns
