Creating and Using Static Reference Source Code
- About Static Reference Source Code
You can write source code (PL/SQL package or SAS format) that is intended for reuse in other Programs. - Creating a Source Code for Use as a Static Reference
If you are creating a PL/SQL Program or SAS Format Catalog to store static reference Source Code definitions, you must create an instance of the Program and map one of its source Table Descriptors to each Table instance required to be read, and install both the Program instance and the Table instance. - Using Static Reference Source Code
In the Program in which you want to use the Source Code:
Parent topic: Defining Source Code
