Creating a Source Code for Use as a Static Reference
If you are creating a PL/SQL Program or SAS Format Catalog to store static reference Source Code definitions, you must create an instance of the Program and map one of its source Table Descriptors to each Table instance required to be read, and install both the Program instance and the Table instance.
Do not define snapshot labels for these Table instances and do not set their Blinding Flag to Yes.
Parent topic: Creating and Using Static Reference Source Code
