Creating and Using Text Variables
The Message is the text content of the Notification. The message and Parameters are part of the Notification definition, and you must click the hyperlink to the definition to define them.
To create the Notification message:
Click the hyperlink to the definition located under the Subject line. The Notification definition's Properties screen appears.
Click Update. The system refreshes the screen and makes the fields enterable.
In the Messages subtab, enter text in the Body field. You can use the Insert Parameter button to insert runtime Parameter values into the body of the text; see Defining Notification Parameters.
Click Apply.
Parent topic: Writing Notification Messages
