Creating Variables through Load Sets
Oracle LSH creates Variables automatically when you define or run Load Sets to load data from an external system. These Variables have the same data type and length and other attributes as the external metadata on which they are based.
You can use these Variable definitions within the Application Area where they are created. You can also copy or move them into a Domain library for the purpose of reuse in other Application Areas, according to your organization's policies.
Oracle LSH creates Variables from Load Sets as follows:
SAS. When you define a SAS-type Load Set, you can choose to create the Load Set's Table Descriptors from the SAS Data Sets you want to load. Oracle LSH creates a Table definition for each SAS data set and an Oracle LSH Variable for each SAS variable. The Oracle LSH Variables and Table definitions are located in the same Application Area as the Load Set definition.
Oracle Tables and Views. When you define a Load Set of type Oracle Tables and Views, you can choose to create the Load Set's Table Descriptors from the Oracle tables or views you want to load. Oracle LSH creates a Table definition for each external Oracle table or view and a Variable for each external column. The Variables and Table definitions are located in the same Application Area as the Load Set definition.
Oracle Clinical Data Extract. When you define an Oracle Clinical Data Extract (DX) View Load Set (either Oracle or SAS), you can choose to upload the Load Set's Table Descriptors from the DX Views you want to load. Oracle LSH creates a Table definition for each DX View and a Variable for each Column. These Variables and Table definitions are located in the same Application Area as the Load Set definition.
Oracle Clinical Global Library. When you run a Global Library Load Set, Oracle LSH creates a Domain with the same name as the Oracle Clinical Domain whose Global Library you are loading (if it does not already exist) and converts all Oracle Clinical Questions to Oracle LSH Variables. If a Question is assigned a Discrete Value Group (DVG) in Oracle Clinical, Oracle LSH also creates a Parameter based on the Variable and gives it a list of values corresponding to the DVG values. Oracle LSH also creates a Table definition from each Question Group.
Parent topic: Creating Variables Automatically
