Explicitly Defining Parameter Sets
You may want to take the time to develop standard Parameter Sets based on standard Variables, logically grouped and meaningfully named.
To create a Parameter Set definition manually, do the following:
- In the Applications tab, navigate to the Application Area or Domain where you want to create the Parameter Set.
- Click Manage Definitions. The system opens the Maintain Application Area (or Domain) Library screen.
- From the Create drop-down list, select Parameter Set.
- Click Go. The system opens the Create Parameter Set Definition screen.
- Enter a Name and Description of the Parameter Set that will help other users determine whether to use this Parameter Set.
- Click Apply. The system opens the Parameter Set screen.
- Under Parameters at the bottom of the page, click Add. The system opens the Create Parameter screen.
- Add as many Parameters as necessary. See instructions at Creating a Parameter and Defining Parameter Details.
- To make the Parameter Set available for use, check it in.
Parent topic: Defining and Using Parameter Sets
