Installing and Setting Up Oracle Business Intelligence Administration Tool
To use the Oracle Business Intelligence Administration Tool, you must do the following on your local PC:
Get the CD-ROM that contains the Oracle LSH files cdrconfig.xml and cdrclient.exe from your system administrator and insert it into your PC. InstallShield automatically runs setup.exe to load cdrconfig.xml and cdrclient.exe to a location you specify on your local computer.
Install Oracle BI Client Tools on your PC in the location specified by your system administrator. The location must match the directory path specified in cdrconfig.xml.
Ensure that cdrconfig.xml has the correct directory path for the Oracle BI Administration tool.
In the Oracle BI Administration Tool, set up connectivity with the Oracle LSH database. See Set Up Database Connectivity for information.
Add and set the following environment variables on the PC through advanced system properties:
ORACLE_HOME Enter the absolute path of the Oracle Home on your PC; for example:
Drive:\Program Files\Oracle Business Intelligence Enterprise Edition Plus Client\oraclebi\orahome -
ORACLE_INSTANCE Enter the absolute path to Oracle BI orainst1 on your PC; for example:
Drive:\Program Files\Oracle Business Intelligence Enterprise Edition Plus Client\oraclebi\orainst -
ORACLE_BI_APPLICATION You must enter the following value exactly:
coreapplication
