Modifying Attributes and Parameters
You cannot add or remove Attributes or Parameters because they are predefined for each Data Mart type. Attributes and Parameters belong to the Data Mart definition. You must check out the definition to update Parameters. In the Data Mart definition you can change Attribute values and, for Parameters, the default value and Read Only and Prompt settings. You should not change anything else or the Data Mart may not function properly.
To change Parameter values at the instance level you can use the Execution Setup. To make your settings available to other instances of the same Data Mart, allow the Execution Setup to be used as a Template. Select Execution Setups from the Actions drop-down list in the Data Mart instance in the Work Area. See Creating, Modifying, and Submitting Execution Setups.
Parent topic: Modifying Data Mart Definition Properties
