Creating, Modifying, and Submitting Execution Setups
This section contains the following topics.
- About Execution Setups and Templates
In order to run an Oracle LSH executable object—Program, Load Set, Report Set, Workflow, or Data Mart—you must create at least one Execution Setup for it. - Creating an Execution Setup
The system creates an Execution Setup automatically if you click Submit directly in the Properties screen of an executable object instance and no Execution Setup currently exists. - Modifying an Execution Setup and Setting Parameters
After you have generated a default Execution Setup you can modify the system Parameters and the default values of the runtime Parameters. The Parameters in the Execution Setup are copies of those in the executable object definition. Modifying them has no effect on the object definition. - Workflow Execution Setups
For information on submitting a Workflow for execution, see the Oracle Life Sciences Data Hub User's Guide. - Removing an Execution Setup
You can remove an Execution Setup if you have delete privileges on Execution Setups of the relevant subtype and also Modify privileges on the parent object's subtype. - Activating a Version of an Execution Setup
Only one version of an Execution Setup can appear in the Reports tab for submission at any one time. - Submitting an Execution Setup
When you have created an Execution Setup, you can submit it to execute the Program, Load Set, Report Set, Workflow, or Data Mart, by clicking Submit in the Execution Setups screen or in the Reports tab.
Parent topic: Common Development Tasks
