Modifying an Execution Setup and Setting Parameters
After you have generated a default Execution Setup you can modify the system Parameters and the default values of the runtime Parameters. The Parameters in the Execution Setup are copies of those in the executable object definition. Modifying them has no effect on the object definition.
To appear in the Reports tab where it is available for general use, an Execution Setup must be checked in and set to Active (see Activating a Version of an Execution Setup). However, from the Execution Setup definition it is possible to submit the Execution Setup even if it is checked out.
See also:
- Removing an Execution Setup
- Activating a Version of an Execution Setup
- Submitting an Execution Setup
This section includes the following topics:
- Name and Description
Click Update to modify the Execution Setup's Name and Description. - Allow Use as Execution Template
Set to Yes to make this Execution Setup available for use as a template to other instances of this Program. Set to No to make the Execution Setup unavailable as a template. This has no effect on any existing Execution Setups based on this one. - System Parameters
The same set of system Parameters are included in all Execution Setups. - Runtime Parameters
The system generates the runtime Parameters in an Execution Setup from the input and input/output Parameters, their default values and other settings, defined in the executable object instance.
Parent topic: Creating, Modifying, and Submitting Execution Setups
