OC Data Extract Views Load Set Parameters
Oracle Clinical Data Extract Oracle Views Load Sets have the following runtime Parameters:
Remote Location. The user submitting the Load Set for execution must enter his or her own remote location/connection combination (or a remote location and shared connection) at runtime to ensure the proper security for the external database. Do not enter a default value.
View Type. From the list of values, select the Oracle Clinical Study or Study Set Access Account that maintains the views you want.
Because this is a predefined, required Parameter you should not change anything except the default value in the Load Set definition, or the Load Set may not function properly.
Parent topic: Oracle Clinical Data Extract Views
