7 Defining Load Sets
Figure 7-1 Process of Creating a Load Set Definition and Instance
Description of "Figure 7-1 Process of Creating a Load Set Definition and Instance"
This section contains information on the following topics:
- About Load Sets
- Creating a Load Set
- Using the Load Set Properties Screen
If you are working in a Work Area, you see the properties of both the Load Set instance and the Load Set definition it references. If you are working directly on the definition in an Application Area or Domain, you see only the properties of the definition. - Defining Table Descriptors
- Setting Load Set Parameters
- About Load Set Planned Outputs
- Defining Different Load Set Types
- Installing Load Set Instances
- Modifying Load Sets
