Setting Load Set Parameters
Each Load Set type has a different set of runtime Parameters. The system uses these Parameters to create the Execution Setup to be used to submit the Load Set for execution.
Because these are predefined and required Parameters you should not change anything except the default value in the Load Set definition, or the Load Set may not function properly. For Remote Location Parameters you should not even enter a default value for security reasons.
The predefined Parameters are described for each type of Load Set:
Parent topic: Defining Load Sets
