OC Labs Load Set Parameters
Oracle Clinical Labs Load Sets have the following runtime Parameters:
Remote Location. The user submitting the Load Set for execution must select his or her own remote location/connection combination (or a remote location with a shared connection) at runtime to ensure the proper security for the external database. Do not enter a default value or change any of the other Parameter settings.
Lab. The user submitting the Load Set for execution can specify the lab for which to load data.
Because this is a predefined, required Parameter you should not change anything except the default value in the Load Set definition, or the Load Set may not function properly.
Parent topic: Oracle Clinical Labs
