OC Randomization Load Set Parameters
Oracle Clinical Labs Load Sets have the following runtime Parameters:
Remote Location. The user submitting the Load Set for execution must select his or her own remote location/connection combination (or a remote location with a shared connection) at runtime to ensure the proper security for the external database. Do not enter a default value or change any of the other Parameter settings.
Study. The user submitting the Load Set for execution must specify the study for which to load real or dummy treatment codes.
Treatment Data Type. If set to Dummy (the default value) the system loads the dummy data. If set to Real, the system loads the real treatment codes, if all security requirements are met.
Parent topic: Oracle Clinical Randomization
