Using the Load Set Properties Screen
If you are working in a Work Area, you see the properties of both the Load Set instance and the Load Set definition it references. If you are working directly on the definition in an Application Area or Domain, you see only the properties of the definition.
See Modifying Load Sets for information on modifying Load Sets.
See also Figure 7-1.
