About OC Global Metadata Load Sets
An Oracle Clinical Global Metadata Load Set loads your Oracle Clinical Global Library definitions and automatically converts them to Oracle LSH definitions as follows:
Oracle LSH loads all Oracle Clinical Questions and converts them to Oracle LSH Variables.
If a Question is associated with a Discrete Value Group (DVG) in Oracle Clinical, Oracle LSH converts the Question to a Parameter and converts its DVG values to a list of allowable values for the Parameter.
Oracle LSH loads all Oracle Clinical Question Groups and converts them to Oracle LSH Table definitions with Columns based on the Variables corresponding to each Question in the Question Group.
The first time you run an Oracle Clinical Global Metadata Load Set, the system creates an Oracle LSH Domain called "Oracle Clinical Global Libraries" and an Application Area for the particular Oracle Clinical Global Library Domain. The first time you run a Load Set for a different OC Global Library Domain, Oracle LSH automatically creates another Application Area for the new OC Global Library Domain.
The use of the term "Domain" is confusing because Oracle LSH and Oracle Clinical use the term differently. The system creates an Oracle LSH Domain to contain all Oracle Clinical Global Library Domains. Within this Domain, Oracle LSH creates an Oracle LSH Application Area for each OC Global Library Domain.
Each subsequent time you run a Load Set for a Global Library Domain, Oracle LSH add any new definitions and modifies any definitions that have been modified in Oracle Clinical. If an Oracle Clinical Question has been removed from a Question Group in Oracle Clinical, Oracle LSH removes the corresponding Column from the corresponding Table. However, Oracle LSH does not delete or retire any Oracle LSH object definitions if their corresponding Oracle Clinical object is retired.
Oracle Clinical Global Metadata Load Sets never delete any metadata because the definitions may be in use in Oracle LSH. The processing is the same in either Full or Incremental mode.
Parent topic: Oracle Clinical Global Metadata
