About Output Validation
By default, outputs inherit the validation status of their Execution Setup. The Execution Setup inherits its validation status from its executable instance. An instance cannot have a higher validation status than its source definition.
Therefore, by default an output cannot have a validation status of Production unless the Program (or other) definition used to produce it has a validation status of Production.
You can manually change the validation status of an output after it is generated; see Changing Objects' Validation Status.
Parent topic: Validating Objects and Outputs
