SAS and Text Load Sets
Define your SAS and Text Load Sets so that the file to be loaded must be specified at runtime. Load a file containing real data in one run, and a file with the same structure but containing dummy data in another run. When you load each file, take care to set the Blind Break system Parameter correctly. The system flags each record in the blinded file as blinded and each record in the dummy file as not blinded.
Parent topic: Loading Real and Dummy Data
