About SAS Load Sets
A SAS Load Set loads data from a SAS file into Oracle LSH. You can define a SAS Load Set for a single data set or for multiple data sets in a SAS XPORT or CPORT file.
Each time you run a SAS Load Set, you load all the data contained in the source file at runtime. You can load a zipped data set file (but not a zipped XPORT or CPORT file).
Parent topic: SAS
