Setting Data Mart Parameter Values
You cannot add or remove Parameters. They are predefined for each type of Data Mart. You can change their value and other settings either in the Data Mart definition, in the Execution Setup definition, or allow the user to set their value in the Execution Setup at runtime.
To change Parameter values and other settings in the Data Mart definition:
For information on the attributes and Parameters specific to each type of Data Mart, see:
Parent topic: Defining Data Marts
