Using the Actions Drop-Down
The Actions drop-down list appears in the upper right corner of many screens in the Applications tab. The actions available in the list vary, depending on the context.
To use the Actions drop-down list, do the following:
- Click anywhere on the Actions field or arrow. The system displays the actions available in the current screen.
- Click the action you want to perform. The system displays the selected action in the field.
- Click Go. The system opens the appropriate screen.
Parent topic: Navigating in the Applications Tab
