Using the Business Area Properties Screen
If you are working in a Work Area, you see the properties of both the Business Area instance and the Business Area definition it references. If you are working directly on the definition in an Application Area or Domain, you see only the properties of the definition.
See Modifying Business Areas for information on modifying Business Areas.
See also Figure 10-1.
