Assign Hierarchy Levels to Domains, Application Areas, and Work Areas
As you set up your Domains, Application Areas, and Work Areas, assign classification values to them according to your design. If you are using Inherited for any object subtypes, objects of those subtypes will automatically be assigned the same values as they are created. You may need to remove some of these inherited classifications. See Allowing Classification by Inheritance and Classification Example.
Parent topic: Design Decision Summary
