Assign Hierarchy Levels to Object Subtypes
If you want to be able to use values in a hierarchy level to label an object, you must assign the hierarchy level to the subtype of that object. For each hierarchy level assignment to an object subtype, you also define:
- Whether a classification to that hierarchy level is mandatory for objects of that subtype
- Whether Inherited classification is allowed for objects of that subtype
- A default classification for objects of that subtype (optional, and may be Inherited or, in the case of outputs, a classification parameter value)
Parent topic: Design Decision Summary
