Examples of Organization Design
Following are several examples of ways to organize Domains, child Domains, Application Areas and libraries. You can use a combination of these approaches or design your own approach.
Examples 1 and 2 are alternative ways to organize data handling for a project that contains multiple studies and for which you need to report on each study separately as well as the project as a whole. The main advantage of Example 2: Project Domain with Reporting on Pooled Data is that you can report on the same data snapshot for all studies and for the project. The main advantage of Example 1: Project Domain with Reporting on Separately Stored Study Data is that you do not need a separate container for unblinded data at the end of the trial, saving space in the database.
You could follow the same procedures without using child Domains. The child Domains serve to organize the Application Areas, making it easier to browse.- Example 1: Project Domain with Reporting on Separately Stored Study Data
- Example 2: Project Domain with Reporting on Pooled Data
- Example 3: Domain for Companywide Reports
- Example 4: Domain for Standard Definitions
- Example 5: Oracle Clinical Definitions
- Example 6: Domain for Cross-Project Analysis
- Example 7: Study or Project Template Domain
Parent topic: Designing an Organizational Structure
