Output Coversheets
You can generate a summary or detailed coversheet for any output in Oracle LSH that lists the validation status of the defined objects that handle the data in the output.
- The summary coversheet gives the validation status of the executable object that generated the output and of each Table instance from which the executable read data.
- The detailed coversheet gives the validation status of each executable object and Table instance that handled the data from the time it was loaded into Oracle LSH to the executable that produced the output. The system examines the immediate source Table instances, then the executables that wrote data to those Table instances, then the Table instances that those executables read data from, and so on to the Load Sets that loaded data into Oracle LSH.
If you have developed good standard operating procedures using the tools provided by Oracle LSH for testing and validating defined objects to ensure that they do not corrupt data, and followed those procedures, then data that was valid when loaded into Oracle LSH should remain valid in Oracle LSH.
Parent topic: Validating Objects and Outputs
