Quality Control Engineer
The Quality Control role allows the View operation on object instances of all types, and the Submit operation on object instances of all executable object types. Therefore Quality Control engineers can run all executable objects in any Work Area in the Application Area and view the resulting outputs, but they cannot modify any objects.
Parent topic: Study 123ABC Quality Control User Group
