Reusing Object Definitions
As you begin to use Oracle LSH, you must define many new objects (though you can use tables, views, data sets, and programs that you have already developed in an external Oracle or SAS system as the basis for Oracle LSH Tables and Programs). But as time goes by, you will be able to reuse existing object definitions more and more, building up libraries of valid object definitions approved for reuse. For example, if you develop and test an enrollment Report Set for one study, you may be able to use the same Report Set definition, with modifications if necessary, for another study.
