Validation Documentation
Oracle LSH allows you to associate job IDs and documents with an object to record the object's validation progress. For example, you may decide that requirements specifications for an object such as a Report Set are required for its promotion from Development to Quality Control. You can associate a pointer to the requirements specifications document with the Report Set definition. For promotion to both Quality Control and Production, your criteria may include successful execution of an object such as a Program. In the Program definition you can include a link to the ID of the job that successfully executed the Program.
For further information, see Validating Objects and Outputs.
Parent topic: Validating Object Definitions and Instances
