Validating Object Definitions and Instances
Pharmaceutical regulatory agencies require that you certify that data submitted to them for approval of a drug is valid. Oracle LSH cannot certify that data entering Oracle LSH from a different system is valid. You must validate incoming data in the source system.
However, Oracle LSH allows you to validate all definitional objects that interact with data within Oracle LSH, and to publish a report coversheet that records the validation status of all objects that touched the report's source data in Oracle LSH, so that you can certify that data remained valid within Oracle LSH.
In addition, Oracle LSH allows you to manually validate report outputs in a Report Set and to reuse the validated outputs even though other reports in the same Report Set are still being developed and must be regenerated.
Parent topic: Overview
