Validation Supporting Information
Oracle LSH allows you to link an object to two types of supporting information for the purpose of documenting that one of your internal validation requirements has been met: Supporting Documents and Supporting Outputs.
Oracle LSH does not enforce the use of supporting information. It is possible to promote an object to a higher validation status even if the object is not linked to the supporting information you require in your standard operating procedure (SOP).
