Work Area Usage Intent and Validation Status
Work Areas have a special attribute called Usage Intent whose allowed values are Development, Quality Control, and Production. Oracle LSH enforces the following rules based on a Work Area's usage intent value and the validation status of the Work Area and all its object instances:
- To be installed in a Work Area, object instances must have a validation status equal to or greater than the usage intent of the Work Area.
- The Work Area cannot be promoted to a validation status higher than the validation status of any of its object instances.
- No executables can be run in a Work Area until the Work Area's validation status is equal to or greater than its usage intent value, except by users with the special Install Qualify Submit privilege on the Work Area. This is to allow testing of the Work Area before making it generally available for use.
- Full installation and Table instance replacement during partial installation are not allowed in Work Areas with a usage intent of Production. This is to protect production data from deletion.
These rules support the following intended Work Area usage:
Parent topic: Validating Objects and Outputs
