5.17.2 Define the Audit Installation
To start journaling, do the following:
Log on as sysadmin; see Log on as sysadmin for details.
Click the System Administrator responsibility link. A new column of links appears.
In the new column of links, scroll down to Security: Audit Trail. In this section, click Install.
If you receive a message asking if you want to install an applet, do so.
The Audit Installations window appears.
Click the Search icon (flashlight/torch) in the toolbar. The Find Audit Installations pop-up appears.
If the icon is inactive, the wrong window is in focus. If necessary, retrieve the Audit Installations window:
In the Navigator - System Administrator window, Functions tab, expand the Security node.
Expand the Audit Trail node.
Click Install.The Audit Installations window appears.
Then click the Search icon in the toolbar.
Click in the Oracle Username field to display the ellipsis (...), then click the ellipsis to display the list of values. Find and select
CDR. -
Click Find. The system returns you to the Audit Installation window with
CDRdisplayed in the Oracle Username column -
Select the Audit Enabled checkbox and click Save.
Parent topic: Start Journaling Internal Tables
