5 Installing Oracle Life Sciences Data Hub
$APPL_TOP, $CDR_TOP, and $JAVA_TOP are all on the middle tier. The Distributed Processing (DP) Server Home directory is located on the DP Server. These may all be physically located on the same computer or they may be located on different computers, depending on your installation.
These instructions include copying files from one of these directories to another. Remember that you need to use FTP if they are on different computers.
During its initial development, the Oracle Life Sciences Data Hub
(Oracle LSH) was known as CDR. Therefore many Oracle LSH-related directories, files,
scripts, parameters, and so on are named CDR or contain the string
cdr. Please think of CDR as a synonym for Oracle LSH as you go
through the installation process.
This section includes the following topics:
- Apply the Oracle Life Sciences Data Hub AD Splicer Patch
- Grant Execute Privileges to the APPS Schema
- Install Oracle LSH 3.0
- Apply Patch 32199023
- Install Online Help
- Install the CdrRuntime.jar File
- Check Non-Default Service
- Set CDR_DB_SERVICE_NAME
- Set CDR_SCAN_HOST_NAME
- Set CDR_SCAN_PORT_NUM
- Run the Health Check Scripts
- Create System Administrator and Security Administrator Users
- Set Profile Values for Load Balancing and Service Name
- Run the Post-Installation Programs
- Gather Statistics on Schemas
- Schedule the Context Index Refresh Program
- Start Journaling Internal Tables
- Increase Memory Available for MetaData Reports
- Grant Security Rights to Seeded Adapters
- Create CDR_USER Role
- Set Up the Notification Mailer
- Set Up the Distributed Processing Server
- Set Up Client Computers
- Install and Configure Java Web Start in Oracle E-Business Suite
- Register Scheduler Job Events to Scheduler Queue
- Mark the OWBSYS Job as Broken
