Job Execution Details
If you click on the Job ID hyperlink in the Job Administration screen, the system opens the Job Execution Details screen.
It displays the following information for the job:
- Submission Properties
The Job Execution Details screen includes values for the following properties in the upper portion of the screen: - Outputs
In the Outputs subtab, the system displays a row for each output generated by the job, if any. - Subjobs
If the job is the running of a Report Set or Workflow, it has subjobs. - Submission Parameters
Submission parameters are Parameters defined for the particular Program, Load Set, Report Set, Data Mart, or Workflow executed by the job. - System Parameters
System parameters are predefined for each object type. - Source Data Currency
The Source Data Currency subtab provides information on the most recent refresh of the data from all sources read by the job. - Log File
Click View Log to see the log file for the job.
Parent topic: Job Information
