System Parameters
System parameters are predefined for each object type.
For further information, see the chapter on each object type in the Oracle Life Sciences Data Hub Application Developer's Guide.
- Name
The system displays the name of the Program, Load Set, Report Set, Data Mart or Workflow instance that was executed. Expand its node (+) to view the Parameters. - Type
The object type of the object listed in the Name column. - Value
The value in effect at submission.
Parent topic: Job Execution Details
