Job Log File Does Not Contain Info after a Long or Failed Execution
If a job executes for a long time or fails and the job log does give enough information, check the Oracle Warehouse Builder (OWB) log.
The OWB log directory is located on the machine where the database is installed, usually in the following location:
$OWB_HOME/log
Parent topic: Job Execution Problems
