Job Runs But Does Not Upload Outputs
If a job runs on an external engine (SAS, Oracle Reports, or XML Publisher) and generates outputs but doesn't upload the outputs to Oracle Life Sciences Data Hub, check the DP Server log.
The DP Server log directory is on the computer where the DP Server is installed, usually in the following location:
$CDR_HOME/<DBName>/log
Parent topic: Job Execution Problems
