Disconnect Blocking Sessions
Before you upgrade, check for and stop any current database sessions.
  1. If WebLogic Server is running, stop it. See Oracle® Fusion Middleware Administering Server Startup and Shutdown for Oracle WebLogic Server (12.2.1.4) at https://docs.oracle.com/en/middleware/fusion-middleware/12.2.1.4/asadm/starting-and-stopping.html#GUID-B57BE53D-F90C-42FB-9B73-27A06AE3768B.
    Log files for the AdminServer and the DMWServer are located in:
    middleware_home/user_projects/domains/DMWDomain/servers/AdminServer/logs
    and
    middleware_home/user_projects/domains/DMWDomain/servers/DMWServer/logs
  2. Log in to SQL*Plus as apps.
  3. Run the following query to find current sessions:
    SELECT 'USER: '||s.username||' SID: '||s.sid||' SERIAL #: '||S.SERIAL# "USER
    HOLDING LOCK", s.inst_id
    FROM gv$lock l
    ,dba_objects o
    ,gv$session s
    WHERE l.id1 = o.object_id
    AND s.sid = l.sid
    AND o.owner = 'CDR'
    AND o.object_name = 'DME_DISC_WORKTABLIST';
    This query returns the user, SID, serial number, and instance ID of each current session.
  4. Disconnect each current session, passing in the SID and serial number:
    alter system disconnect session 'SID, serial_number' IMMEDIATE
