6 Upgrading Oracle Thesaurus Management System to Release 5.3.1
This chapter describes the recommended approach to upgrade an existing Oracle Thesaurus Management System installation to Release 5.3.1. Supported upgrade paths for TMS Database include:
Release 5.0.1 or 5.0.2
Release 5.1, 5.1.1, or 5.1.2
Release 5.2.1
Release 5.2.2 or 5.2.3
Release 5.3
Since the architecture of the technology stack changed, the supported upgrade paths for TMS Front End and TMS Report Server include:
Release 5.2.1
Release 5.3
For other older TMS releases, a fresh installation of application tier technology stack (see Install and Configure the Oracle Application Tier), and TMS Front End and TMS Report Server (see Installing Oracle Thesaurus Management System Application Components) are required.
Be sure you are using the latest documentation:
Check My Oracle Support Article ID 1572864.1 for any known installation issues.
Check the Oracle Thesaurus Management System documentation page on the Oracle Help Center at
https://docs.oracle.com/health-sciences/tms-531/tms-docs.htmto be sure you have the latest version of this guide. -
Check My Oracle Support Article ID 2706264.1 for the latest Oracle Thesaurus Management System Release 5.3.1 Release Notes.
Review Prepare to Install Oracle Thesaurus Management System for system requirements and planning information.
Critical Patch Updates: See Download Oracle Critical Patch Updates.
Oracle Database 12c (12.1.0.2) and 19c (19.3.0.0) include many new features including multitenancy, which allows you to create one or more pluggable databases (PDBs) contained in a single root or container database (CDB). You can install Oracle Thesaurus Management System on either a pluggable database or a non-CDB database (as in 11g). For more information on multitenancy, see:
For information about upgrading and migrating your existing database, see the "Installing and Upgrading" document at:
For more information about new features, see Oracle White Paper Plug into the Cloud with Oracle Database 12c at http://www.oracle.com/technetwork/database/plug-into-cloud-wp-12c-1896100.pdf or Oracle Database 19c Introduction and Overview White Paper at https://www.oracle.com/a/tech/docs/database19c-wp.pdf. For more details on 12 c version, see Oracle® Database New Features Guide 12c Release 1 (12.1) at http://docs.oracle.com/database/121/NEWFT/toc.htm. For details on 19c version, see Oracle Database 19c What's New at https://docs.oracle.com/en/database/oracle/oracle-database/19/whats-new.html.
Distributed environments are no longer supported in this release.
This chapter includes:
- Upgrade Oracle Clinical (If Integrated with Oracle Clinical)
- Install Oracle Database
- Back Up Your Database(s)
- Upgrade Oracle Database
- Upgrade and Configure the Application Tier Technology Stack
- Install the TMS Database Server Code
- Upgrade a TMS Database
- Upgrade Cloned Databases
- Run Scripts to Gather Schema Statistics for the 12c or 19c Optimizer
- Upgrade the TMS Front End
- Upgrade the TMS Reports Server
