5 Installing Oracle Thesaurus Management System Application Components
The Oracle Thesaurus Management System Front End includes:
The Oracle Thesaurus Management System Forms Server, which is required for the primary Oracle Thesaurus Management System application
The OPAXDO service for reports generation
You must install the TMS Server code and database objects before you install the Front End.
If Oracle Clinical Front End or previous versions of TMS Front End (which are supported for Front End upgrade) was already installed on the application server, follow instructions in Upgrade the TMS Front End as the needed components were already created by previous Oracle Clinical or TMS Front End installation.
Before installing TMS Front End, you must start the FRDomain services (AdminServer, WLS_FORMS, and WLS_REPORTS) so that all required components will be created. After the FRDomain services have started, stop all these as the TMS Front End installation require to have all the FRDomain services stopped.
This section includes:
- Restart Computer and Stop All Servers
- Install the TMS Front End
- Make the Java Runtime Environment Available for Download
- Install the TMS Reports Server
- Verify the Application Tier Installation
- Verify and Fix Environment Variables
- Set Up Automatic Startup
- How to Start Servers Manually
- Stop the Servers
