Omission Management Reports
TMS includes the following reports under the Omission Management menu:
- VTA/VTI Creation Report
- Classification Statistics Report
- VT Domain Differences Report
- VT Auxiliary Classifications Report
- Unclassifiable Indication Omissions Report
- Indications Assignments Report
Parent topic: Omission Management
You can view the verbatim term assignments (VTAs) and verbatim term individuals (VTIs) created for a particular dictionary within a specific time period and the author of the VTA.
The VTA/VTI Creation Report displays the following:
The affected Dictionary
The affected Domain
The Verbatim Term for which the assignment is made
The Classification Type: VTA or VTI
The Dictionary Term to which the VT is assigned, and its ID
The date and time of the VTA or VTI creation
The author of the VTA or VTI
To generate a VTA/VTI Creation Report:
Parent topic: Omission Management Reports
This report summarizes the state of classification in the TMS repository. It displays the number of outstanding omissions, misspelled terms, VTIs, approved and unapproved VTAs and the total number of terms.
The Classification Statistics Report has two sections, which display the following:
Omissions Displays the Domain on which the report is run, the number of Unique Verbatim Term Omissions (VTOs) and the total Omissions.
VTAs Displays the Domain, the approval status of Accepted and Misspelled VTAs against various Search Objects as well as the Totals.
VTIs Displays the Domain and the number of Accepted and Misspelled VTIs that were created by direct or manual match or loaded.
To generate a Classification Statistics Report:
The VTA/VTI Domain Differences Report compares the VTAs and VTIs in two domain/dictionary combinations, returning those that are mapped to different terms in these domains.
To run the VT Domain Differences Report:
The VT Auxiliary Classifications report lists all VTI classifications in a particular domain/dictionary combination that have auxiliary information. For each VTI the system displays:
The auxiliary levels and values
The VTI ID
The dictionary term and its ID, code, and alt code
The instance and the user or system that created the VTI
To run the report:
The Unclassifiable Indication Omissions report shows, for a particular dictionary/domain combination, indication omissions that are not classifiable because the related indication and route of administration combination did not find a higher level term path when the source term is classified to a VTA or dictionary term.
For each source term the report displays:
The source term ID, the external system where it originated, and any external system values associated with it
The instance
The verbatim term and term type (VTA or VTI)
The lower dictionary term and its ID and code
To run the report:
The Indications Assignments report shows the current indication assignments for the local instance as a whole or for a particular dictionary and/or domain. For each assignment the report displays:
Indication
Route of administration
Route of administration is added for the TMS 5.3 release.
The higher dictionary term and its ID
The user or system that created the assignment
The Valid From date
To run the report:
